Re: H-farmall firing on 1 and 4 cyl.
Posted by El Toro on April 07, 2011 at 13:12:04 from (108.3.156.106):
In Reply to: H-farmall firing on 1 and 4 cyl. posted by Randy Bridges on April 06, 2011 at 19:08:49:
Make sure you have your wires in this firing order on the cap. Make sure the valves aren't opened on those cylinders. Hal
2-1
4-3 As the rotor turns CW.
