Re: IAC 300 Utility Tractor
Posted by Handyman on April 07, 2011 at 14:18:58 from (216.201.66.234):
In Reply to: IAC 300 Utility Tractor posted by Trucker101 on April 07, 2011 at 11:34:38:
there should be timing marks on the gears for you to line things up correctly, just make sure your number one cylinder is at TDC and things should line up for you. that spot where your leak is coming from is probably sealed with an O-ring and I would recomend that you replace it before putting it back together , or you may find it leaking again real soon.
