supe c sticking in two gears
Posted by DENNIS REID on April 07, 2011 at 16:19:26 from (74.232.60.65):
I pulled the shifter out of tranny, and it looked very worn. I had a man weld onto the end of the shifter to make it thicker. Not much improvement. It also make a growling sound sometimes, which I suspect is the transmission trying to pop out of gear.
Any one have an idea the deminsions of the end of the shifter which moves the gears?
thanks so much.
Dennis Reid
770.537.9769
