Re: Steps for a Farmall 240 NF Row Crop - Anybody Make Th...
Posted by farmallhal on April 07, 2011 at 16:42:39 from (76.4.172.14):
In Reply to: Re: Steps for a Farmall 240 NF Row Crop - Anybody Make Th... posted by gene bender on April 07, 2011 at 10:23:39:
Gene, thanks for the offer and I would certainly like to explore that possibility. Do you have some photo's you can email me? I will only consider something that is fastened to the tractor with bolts and not interested in something that needs to be welded to the tractor. Either using existing holes or bolt locations on the tractor for direct attachment or attachment to some type of adapter plate using existing hard points on the tractor. You probably know I'm an originality type and don't want to modify the tractor from an original but a step is certainly needed for these legs. I probably only need something for the left side (clutch side) as that is how I usually mount my tractors as there is usually less "operative clutter" on that side. My email is open so please send a note and photos if you will. Thanks again, Hal.
