Re: 43 m
Posted by Janicholson on April 08, 2011 at 06:39:07 from (199.17.6.77):
In Reply to: 43 m posted by jim iowa on April 07, 2011 at 21:30:35:
I think that if it was operated for two hours and checked out in terms of oil pressure and smoke that it is a pretty good buy. What else can you purchase for 2000 that will provide the service you will get from it. With good tires it should please both seller and buyer. Jim
