Re: Super C stalled with pictures
Posted by Dean Olson on April 08, 2011 at 07:39:42 from (166.205.15.4):
In Reply to: Re: Super C stalled with pictures posted by mkirsch on April 08, 2011 at 05:14:37:
The only thing that could have caused that is if the new
thermostat stuck closed. It didn't feel or smell hot. I did pull
about a pint of oil on the side of the road, checking for
antifreeze, I had gloves on but did manage to splash some,it
was hot but didn't burn me. I did touch the side I of the block.
Again warm but not any hotter than normal. Radiator didn't
overflow. Only lost a enough to wet the block from the head
gasket.
I ran fine for about the 45 minutes it took to plant and then
made the 2 mile trip home in 4th wide open throttle.
The only difference was the radiator cap was loose after the
incident.
