Re: Bn lights
Posted by gene bender on April 08, 2011 at 09:48:32 from (67.55.227.7):
In Reply to: Re: Bn lights posted by todd heck on April 07, 2011 at 17:10:39:
You should be using pos for ground unless domeone has changed it and to make sure you have a good ground you can run a wire from the battery ground to the lites
