Re: 12 volt ground
Posted by Janicholson on April 08, 2011 at 14:47:13 from (199.17.6.77):
In Reply to: 12 volt ground posted by Jeff Dexter on April 08, 2011 at 13:20:08:
The 12 volt generator equipped Farmalls were mostly positive ground. Changing to negative ground is possible with mechanical regulators by polarizing the generator. (jump for one second between the Arm and Bat terminals on the regulator to polarize (engine OFF))
The terminals are big and little. If you look close you will see which way it was attached.
Do that first, and polarize second, then start. If the amp gauge reads backwards, it can be reversed by changing the wires to the opposite meter posts. Jim
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
