Or you could plow in reverse. Then you could easily see where you've been.
Seriously though, I've been meaning to ask you about some stuff you've built in the past. I think I remember seeing some kind of 90 degree gear box that you attached to the belt pulley in order to run a shaft that is parallel with the longitudinal axis of the tractor.
What I'm after is that I want to build a shredder that mounts in front so I can shred without walking on stuff first. I could run a long chain but then I have to figure a way to keep tension on the chain while allowing for floating action.
It might be easier to use a regular telescoping pto shaft and that's where the 90 degree drive off the belt pulley comes in.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
