Re: new voltage regulator
Posted by gene bender on April 08, 2011 at 17:45:36 from (67.55.227.7):
In Reply to: Re: new voltage regulator posted by oldiron29 on April 08, 2011 at 15:55:36:
That reg is made to replace the cut-outs that were used before around 1949 when the tractor had a 4 position sw for hi- charge. Now with the new regulator you dont use the wire that went from the field back to the lite sw for hi-charge. It should have worked good. The manufacturer of these regs had a very good article in Red Power explaining their use and the ones i have bought worked well. By the way do you know the Delco Remy # on the tag.
