Re: IH Wheel Weights- Different Question!!!
Posted by Kippster on April 09, 2011 at 00:51:31 from (24.144.201.222):
In Reply to: IH Wheel Weights- Different Question!!! posted by Ron in Nebr on April 08, 2011 at 20:36:57:
Sounds like your tractor works for her keep. This method is cheap and effective. Casting wheel weights from concrete isn't very hard. They don't turn out like factory perfection, but they darn sure do the job. I have 2 sets on my 48 H. Put some heavy all-thread in the holes in the wheels. Measure center to center on your all threads then you know what spacing your pipe needs to be in the concrete form. Let the pipe stick up out of the concrete some. This allows the pipe to take the clamping force, not the concrete. Make your form from whatever you can find. I used an old semi rim with the center cut out and filled it 1/4 full. Gives you a nice lip to hold onto when changing weights. Paint em up and stick em on there. Don't have any idea how much they weigh, but they are some heavy buggers! lol Kippster
