Posted by CNKS on April 09, 2011 at 08:02:44 from (216.144.104.128):
In Reply to: Re: super a 1 posted by william davis on April 09, 2011 at 06:33:16:
The grill has the wider lower metal piece like the Super C. Since the radiator is taller there is noticable space between the top of the hyd reservoir and the bottom of the gas tank. All casting codes should end in Z, unless a casting has been replaced. However there were about 600 SA's produced in early 1954. Also the A1 has a water pump. If it has a temperature gauge the sensor is in the UPPER radiator outlet. The engine block should have C123 cast on it. Chassis serial begins with FAA1, first one produced has serial 356001; engine serial prefix is FCM.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
