Re: 400 piston rod twisted
Posted by old on April 09, 2011 at 11:11:25 from (4.245.8.85):
In Reply to: 400 piston rod twisted posted by bugspot on April 09, 2011 at 10:31:31:
You could have a few different problem all of which would cause that. I would not run it till you found out what the problem is. Bent rod, wrist pin problem in the piston, rod bear is out, or even a cracked piston. No matter what I would pull the pan off and since you have the head off any how pop that piston and rod out to have a good look at it
