Re: 450 TA Help!
Posted by Janicholson on April 09, 2011 at 20:57:30 from (67.72.98.45):
In Reply to: Re: 450 TA Help! posted by labman98 on April 09, 2011 at 17:06:35:
Both are available. Hicapacity is one brand, and there are others. Stay clear of a brand called Mechanical Diode. A contributor here named Kevin Meier sells all the parts and whole rebuilt units.
The component in yours that is failing is called a one way clutch. It is a device that looks like a roller bearing. It is at the rearward end of the TA near the transmission. It prevents the TA housing from turning backwards, but allows it to turn forward. This is the sole component that is currently slipping when it should hold. If you are a mechanic and tool friendly, with the ability to safely split the tractor you can do it.
If not, it is a job for others. Jim
