Re: hydraulic tank
Posted by D Slater on April 10, 2011 at 09:03:49 from (184.15.22.100):
In Reply to: Re: hydraulic tank posted by sflem849 on April 10, 2011 at 07:16:21:
Both types of pumps and injectors can be used with each other. Pumps set ideal for one type injectors may need a little adjusting to be ideal with the other type injectors. Can you bolt other type pump them on and run? yes if pump and timimg are okay. I was referring to tank return line,ETC. A pump has 3 lines to primary, scavaging pump on rear. B pump has 2 lines to just a primary pump on rear. IH did sell B pumps and parts to replace pumps on tractors equiped with A if wanted. Open injectors also.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
