Re: What kind of Hydraulic oil to put in my M and Super C?
Posted by rustyfarmall on April 10, 2011 at 10:32:26 from (209.152.78.140):
In Reply to: What kind of Hydraulic oil to put in my M and Super C? posted by Faster346 on April 10, 2011 at 08:31:06:
You are low on fluid, and the system has air in it. I would drain the belly pump and refill with Hy-Tran. 6 or 8 quarts will fill it, but you will probably need to add more oil after putting the loader through its paces.
