super H timing
Posted by Mike Lumley on April 10, 2011 at 15:57:13 from (69.99.214.253):
Attempted to time my Super H today after recent top end overhaul. With timing light lining up marks per manual at idle and full throttle, the mark (on crank pulley) would what i would call "hunt" or run in advance from pointer on engine. Any suggestions? I have installed electronic ignition. Could there be gear wear or distributor shaft wear?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
