Re: 560 fuel problems
Posted by Armand Tatro on April 10, 2011 at 16:20:23 from (98.227.26.140):
In Reply to: 560 fuel problems posted by ERKEL3 on April 10, 2011 at 15:28:04:
Are you sure gettingFULL FLOW to the injector pump? You need to take the fuel line completely apart and let the fuel flow for at least 3 min. in to a container to be sure you have full flow. I have those hoses go bad on the inside and when you just crack that fitting you will get a dribble and think you have fuel. BTDT!!!! Armand
