Re: Question for Janicholson - TA Help
Posted by Heat Houser on April 10, 2011 at 19:09:38 from (69.66.35.73):
In Reply to: Question for Janicholson - TA Help posted by labman98 on April 10, 2011 at 18:10:21:
If it won't hold on the low side, typically #60 Clutch Roller has flat spots worn on it and it won't jam up the planet carrier and hold it stationary.
If you have more time than money, replace the rollers and springs. If you have money, replace the assy. I would inspect the rest of the parts when you have it split.
