Re: Question about hydrolics for M
Posted by Janicholson on April 10, 2011 at 20:50:50 from (67.72.98.45):
In Reply to: Re: Question about hydrolics for M posted by James Riley on April 10, 2011 at 12:47:55:
The over full will not hurt anything unless you attach a single acting cylinder to it, and that is not the case at this point. A double acting cylinder on your hitch will use oil out of the reservoir, and give back oil out of the other end of the cylinder in almost equal proportions. No issue. If it was dry and not working because of lack of fluid, it might take some to fill the air spaces, do not fret. Just do it. Jim
