Re: 560 diesel fuel problems
Posted by Bob on April 11, 2011 at 05:29:47 from (64.255.159.192):
In Reply to: Re: 560 diesel fuel problems posted by ERKEL3 on April 11, 2011 at 04:29:13:
The metering valve is located inside, beneath the top cover of the IP, which is held on with 3 screws.
If you decide to take a peak in there, be aware the possibility exists to jam the governor mechanism causing engine runaway if the cover is not installed carefully and correctly.
Below is a link to a photo of a similar pump on the Ford Forum showing the location of the lever on the metering valve.
(Hope your's isn't rusty like that on the inside!)
