Posted by sflem849 on April 11, 2011 at 08:08:11 from (69.197.84.78):
In Reply to: M 5th gear posted by Haas on April 11, 2011 at 06:53:15:
Can you pull the shaft from the belt pulley hole? That would save A TON of work.
I think on some models you can change that front bearing without popping the top. Not sure if there is enough room on all of them. I had the top off when I did my H so I didn't even try. Also, I always forgot about inspecting 5th through the belt pulley because I went in my H for a broken differential carrier and happened into the bad 5th gear.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
