Re: Seals for H PTO housing
Posted by Nebraska Kirk on April 11, 2011 at 10:14:11 from (207.91.4.197):
In Reply to: Seals for H PTO housing posted by Farmallb on April 11, 2011 at 10:03:51:
The original seal had a leather sealing lip and was 1/2" wide.
One modern seal is all you need. You can use two if you want, but not necessary, if you do, pack the gap between the two seals with grease.
