Re: Question about hydrolics for M
Posted by Janicholson on April 11, 2011 at 10:22:38 from (199.17.6.77):
In Reply to: Re: Question about hydrolics for M posted by James Riley on April 11, 2011 at 09:14:46:
Did the hydraulics work?
Lowering the pump requires ready rods to screw in place of the bolts, allowing slow but controlled lowering. All elbows are removed, the top pipe fittings , and the control lever.
Then the drive shaft (above/inside the plate on the bottom of the tractor)
Pull the cotter pins and it comes out.
There are disassembly instructions in the Search for archives. Jim
