Re: farmall a magneto gear
Posted by Jim Becker on April 11, 2011 at 11:03:45 from (173.57.163.253):
In Reply to: farmall a magneto gear posted by farmallhal on April 11, 2011 at 08:02:10:
That is probably what you are seeing. One of the teeth on the cam gear should have a single mark and the other a double mark. The single aligns with the crank gear mark. The double aligns with the mark on the governor/magneto gear. You have to turn the crankshaft 2 full revolutions to bring the proper mark back to the starting point.
You can static set the timing before you ever start the engine (procedure in the Owner's Manual). It shouldn't be necessary to do any additional adjustment after you start it.
