Re: Straight weight or multi viscosity
Posted by Enar on April 11, 2011 at 15:37:36 from (98.244.241.123):
In Reply to: Straight weight or multi viscosity posted by BruceS. on April 11, 2011 at 07:23:20:
Go with the 85/140/ Less leaks and better lubrication. You might think about mixing some Lucas Transmission Fix in with it. Quiets those shifts down 100%.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
