Posted by Janicholson on April 11, 2011 at 15:44:09 from (199.17.6.77):
In Reply to: Re: hyd lift posted by Marlin taylor on April 11, 2011 at 12:59:37:
The dip stick is dry when there is only one quart out of 6 missing. It should not be run dry Advice from "Sate" is good. Or fill it and pull on the control rod. If it slows the engine, and makes noise and wants to pull the rod back to the detent (hold) position, it is a good pump, and could be used. If nothing, it may be disconnected already. Making sure it is disconnected is the best option if you intend not to use it. If it leaks oil when filled, it must be fixed, disconnected from the drive, or removed. Best of luck, Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
