If the wheels are in too far, the mower deck tends to catch on the rear tires when you go in reverse. So best to set the wheels out some. I have my wheels dished in, but the rims are set as far out as they will go. This setup makes the rear track a little wider than the mower cut (with 11.2 x 24 tires) which you may not like. With the tires set out like this, you get added stability on hilly ground and also minimize the problem of the deck catching the rear tire lugs in reverse. Also, because of the tire problem, you don't want to set the mower lift so that it raises too high. The front tread setup doesn't matter much.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
