Posted by 756puller on April 11, 2011 at 18:34:05 from (96.31.182.58):
In Reply to: 806 Shifter posted by Rick in Michigan on April 11, 2011 at 07:41:13:
remove the plate that is right in front of the voltage regulator, you should see a shaft going into a bigger pipe, check to see if there is a roll pin in the drilled hole of the collar the small shaft goes into
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
