Re: Farmall M 3pt hitch?
Posted by Red John 2 on April 11, 2011 at 19:26:36 from (72.188.248.231):
In Reply to: Farmall M 3pt hitch? posted by Jesse Fenner on April 11, 2011 at 12:23:00:
Jesse, Go for it! A 3-point hitch for H or M is the best investment available. Be sure to get the dual hydraulic cylinder version. (A single hydraulic cylinder version is available but only has half the lifting power.) I have been using the dual versions on my 42 M and 53 SH for about 20 years. You can make your new system even better by simply installing a hydraulic pump from a SM or 400 along with the IH "Christmas Tree". Then you will have LIVE hydraulics and 3-Point hitch. (Installation instructions are readily available.)
A fork-lift attachment is inexpensive and is extremely handy. By adding front weight rack and weights you will be able to lift a whole lot more than you may imagine.
Good luck.
