Re: 140 Ammeter
Posted by K-Mo on April 12, 2011 at 08:38:35 from (67.55.164.37):
In Reply to: Re: 140 Ammeter posted by joe33 on April 12, 2011 at 04:32:38:
I suspected it would raise an eyebrow or two.
Let me add this-- It takes a thorough understanding of the overall charging system to get information other than charge current from an ammeter.
A voltmeter provides more direct information without needing to know how the system operates.
1. Turn on the ignition, the voltage gives an indication of battery state of charge. 12.6-100%, 12.4-80%. About 10%/tenth of volt.
2. While cranking it indicates the quality of the battery. Draws below 9 volts indicates battery may be weak.
3. While running it indicates battery charging. 13-15 volts indicates charging system is working.
Of course it depends on the type and resolution of he voltmeter.
Did that help or did I dig myself in deeper?
K-Mo
