Re: Farmall M Loader Wont Lift (Pics Video Inside)
Posted by mkirsch on April 12, 2011 at 10:14:00 from (64.80.110.75):
In Reply to: Farmall M Loader Wont Lift (Pics & Video Inside) posted by Faster346 on April 11, 2011 at 20:51:13:
Check the oil with the loader up as high as it will go.
If it's empty, then you need an auxiliary reservoir.
If there is still oil, the air bubble might be your problem.
Those hoses will require some oil to fill them, so your reservoir will end up going a quart or two low once you get all the air out.
