SuperAV problems
Posted by GTG on April 12, 2011 at 14:48:22 from (98.251.205.209):
Just bought a SuperAV at a good price. Previous owner had it laid up for about 3 years. It starts easily, but then runs fast and then slows and then fast again, no matter what I do with the throttle. Is this a problem with the governor? Also, it runs hot after just a couple of minutes. I don"t know if it has a water pump or not. Could this be a bad impeller. The radiator was replaced about a year before it was laid up. I"m new at this and any help would be appreciated. Thanks.
