Re: Re: Re: H belt pulley to pump
Posted by Wardner on July 27, 2000 at 08:47:48 from (63.23.216.205):
In Reply to: Re: Re: H belt pulley to pump posted by The Red on July 27, 2000 at 08:32:25:
Red, I do not own the unit and do not know what the psi or gpm is. I suspect that they are only available with a single acting valve. I wouldn't own one unless I were to put it on a non-working show tractor. They were also available for mounting on the rear PTO. I would guess the IH Lift-all is a more rugged unit.
Post A Followup
: Re: Re: Re: Re: H belt pulley to pump
