Re: International (Farmall) 806 breaks shear pin
Posted by Allan In NE on April 13, 2011 at 04:22:51 from (148.66.88.254):
In Reply to: International (Farmall) 806 breaks shear pin posted by Mike Lane on April 12, 2011 at 16:34:01:
Knocking is more than likely coming from the no-load slack in the drive train.
Replace the shear pin on the mower and it will probably be just fine. I'd use a hardened pin too.
Allan
