Posted by El Toro on April 13, 2011 at 06:17:27 from (108.3.156.106):
In Reply to: Re: Ignition switch posted by Albo5000 on April 13, 2011 at 05:55:17:
Don't you have a separate rod or button to push when cranking the engine? I had one of those tractors back in the 70's. The ignition switch just supply's battery voltage to your ignition. It may feed voltage to your lights. You probably can spin the engine over without the ignition switch on if it is still original. Hal
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
