Re: Thread Sealant for Gas Tank Plug
Posted by El Toro on April 13, 2011 at 17:07:03 from (108.3.156.106):
In Reply to: Thread Sealant for Gas Tank Plug posted by Wilks54 on April 13, 2011 at 07:25:20:
Get some Gasoila "soft set" from your local plumbing supply store. I also use some teflon tape and stay above the starting threads. Then use a light coat of the soft set. I use it on natural gas pipes too. Hal
