Re: Ignition switch
Posted by El Toro on April 13, 2011 at 17:16:09 from (108.3.156.106):
In Reply to: Re: Ignition switch posted by Albo5000 on April 13, 2011 at 06:28:01:
Use a volt meter or test lite to see you have battery voltage at your coil with the points open. Be sure to pull the ignition switch to the on position. That ignition switch has nothing to do with your starter. It's purpose is to supply battery voltage to your coil and points. When you push the switch in that kills the battery voltage to your coil and the engine will quit. If you don't understand this info get a friend to help you that's an old retired mechanic. Hal
