Re: 656 Wheel Weight Issue Update
Posted by Ron in Nebr on April 13, 2011 at 22:17:28 from (66.252.113.182):
In Reply to: Re: 656 Wheel Weight Issue Update posted by Allan In NE on April 13, 2011 at 04:15:55:
Yeah, not sure how strong those stamped wheels are...one's been cracked and welded before. Really should get some cast centers and be done with it.
Hopefully no worries about overstressing the frame, we've got a bigger loader tractor for the heavy loader work, this one's mainly used as a "spare" and for small jobs, just would be nice to be able to move a little sand around once in awhile. The way it is now, if I get more than half a bucket full, I usually wind up having to dump it out or I'm stuck...
To the other posters- can't hang weight on the 3 point, since this tractor doesn't have one. And I'm in north central NE.
