Re: M Differential Shaft Seal
Posted by WY JERRY on April 14, 2011 at 08:07:26 from (72.21.73.208):
In Reply to: M Differential Shaft Seal posted by CSK on April 13, 2011 at 20:23:23:
The old one can be a bear to get out, but it will come - you have to worry it to death.
I have used seals from NAPA (number NOS 28687 I think) which have worked well. The counter guy should be able to cross the IH number (bring all three numbers). You will find the new seal will be thinner than the old original seal. This can be advantageous because you can (and should) position the seal on an area on the shaft that has not been worn by the previous seal.
Some folks use one seal here, others two. Personally I think one is good. Just have the shaft and housing nice and clean, and lubricate the seal with a little gear oil when sliding the shaft through.
Hope that helps
Jerry
