Just remove the original two IH cap screws and turn the original IH generator bracket upside down and reinstall the original dot head bolts in the same holes as before. It is as simple as it sounds. By turning the bracket upside down the alternator is moved to a position about an inch or so higher where you have some excess room available. In fact, I was able to use the existing IH generator belt with the alternator I used and still had a small amount of adjustment available if needed and didn't have to play with the adjustable split pulley on the fan. I used the Hitachi 14231 alternator which is about an inch smaller in diameter then the Delco 10-SI everyone talks about but they are too large for the H under the hood unless you know vodoo magic or have other magicial powers.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
