Re: Super A overheats
Posted by Scotty HOMEy on April 14, 2011 at 20:52:32 from (70.105.230.118):
In Reply to: Super A overheats posted by CNKS on April 14, 2011 at 18:27:43:
I tend to agree it's ot your cooling system.
That one burp you got out of it would be typical -- could be from being slightly overfilled, could have been caused by a bubble at the back end of the head or block expanding and forcing some out. Couldn't hurt to flush it. And Jims notion about finding a thermometer to aim at it might be helpful.
I'd suggest checking your timing, to make sure first that it is set correctly and that it's advancing the way it should. A retarded spark, especially with a variable advance at high rpms, will cause overheating. It ignites the fuel late enough in the stroke that it is still burning when the valve opens and you have combustion in the upper part of the head where the cooling isn't up to it. Signs of this would be excessively hot manifold or muffler -- and it can happen even with a light load.
