Re: Got some Howling???
Posted by mkirsch on April 15, 2011 at 05:46:10 from (64.80.110.75):
In Reply to: Got some Howling??? posted by BohemianJon on April 15, 2011 at 05:18:44:
Take it apart, see what's wrong, and fix it...
Unfortunately, that's the best advice anyone can give. Anything could be wrong in there causing the howling.
Use wood wedges to keep the front end from pivoting from side to side when you start removing wheels and final drives from the rear. The tractor is not balanced well once you start taking it apart, and could turn turtle on you.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
