Re: IH 435 sq baler bearing needed
Posted by Brownie 450 on April 15, 2011 at 07:02:58 from (66.43.241.198):
In Reply to: IH 435 sq baler bearing needed posted by lstra on April 14, 2011 at 19:21:28:
Not familiar with this unit---is the bearing a bronze bushing or a sealed bearing? If bronze, you can take measurements & get a replacement from a bearing supply house. If sealed, get measurements & there should be a common replacement available.
