Re: Weight of an H
Posted by rustyfarmall on April 15, 2011 at 13:02:49 from (209.152.78.140):
In Reply to: Weight of an H posted by tractor300 on April 15, 2011 at 12:25:47:
I think that is correct. Everyone also needs to understand that a "no options" tractor was just that. The PTO, belt pulley, and the hydraulic belly pump are ALL options, and I would guess the weight of EACH to be in the 75 to 100 pound range, so now the weight is up to about 4,200 pounds. Adding just one set of rear wheel weights and it is up to 4,500, and we haven't even calculated the weight of the fluid in the tires.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
