Re: Model 340 Tachometer
Posted by rustyfarmall on April 15, 2011 at 13:09:53 from (209.152.78.140):
In Reply to: Model 340 Tachometer posted by LRRifleman on April 15, 2011 at 12:57:55:
You would need to send that tach to someone to be rebuilt, or buy a new tach if one for the 340 utility is available, but before doing that, pull the core out of that new cable and then grease it up good as you slide it back into the housing. Make sure both ends of the core engage securely into the female drive sockets.
I have cured several erratic reading speedometers by simply lubing the cable.
