Re: Cub value and what to look for...
Posted by muleboss on April 15, 2011 at 15:33:03 from (67.239.123.49):
In Reply to: Cub value and what to look for... posted by grayrider on April 15, 2011 at 13:49:53:
Check for cracked radiator bolster. It could have been frozen and broken. If it has been repaired good that is okay unless you want a trailer queen.
It it has been frozen check head and block behind the distributor or mag area for crack.
Check form excess noise in rear end/ transmission area.
Check for broken engine ears.
