Re: How big of a 3pt disc can my H handle?
Posted by rhtx55 on April 15, 2011 at 17:50:09 from (207.119.48.51):
In Reply to: How big of a 3pt disc can my H handle? posted by Yooper Farmall on April 15, 2011 at 06:54:06:
I would look into getting a hydraulic lift pull type plow & disk, and use the original drawbar, they work much better than a 3 point, the issue with a 3 point is when you hit a rock or tree root, going over backwards isn't condusive to good plowing or disk work, the pull type equipment comes with a "break-away" tongued hitch and if you get the later models already on rubber tires, and you can run down any road.
