Re: what does FIAT have to do with Case-IH ?
Posted by scotc on April 15, 2011 at 20:31:06 from (75.245.145.119):
In Reply to: what does FIAT have to do with Case-IH ? posted by couv on April 13, 2011 at 19:07:59:
Fiat also own Iveco, who sells the Cummins B series, as their own, which it is, since it is built through a joint venture between Cummins and Case.
That's why the construction equipment is now running the Iveco motor. It's a B series, with the geartrain driven off the back of the crank instead of the front. It looks like it's mounted backwards.
