Re: How big of a 3pt disc can my H handle?
Posted by Janicholson on April 15, 2011 at 21:26:50 from (67.72.98.45):
In Reply to: Re: How big of a 3pt disc can my H handle? posted by Yooper Farmall on April 15, 2011 at 07:07:31:
Adjusting a plow to work will be easy enough to make it a good option. All equipment works well when set correctly. I have worked 2 point plows on 300s 350 350U and 400 and 3 points on other tractors including a M with a home made 3point. Adjustment was just that. Do it and sense you are not making a 300 acre issue it will be just fine.
A 7' disk is all it will want. 250 pounds on the front will help, the 300 got a little light with an 8' disk, and it was really more than it needed.
Jim
